- Thread starter
- #501
Ceddy
- 847
- 42
- May 10, 2006
Reading,
Pennsylvania
Ceddy can correct me but I think there are a few other maps/tables for things like initial injector pulse widths and cold start enrichment that may need tweeking to be perfect with the larger injectors but should work ok as is.
The lowest value in the DeadTime table (4.69 v) is used as a Cranking PulseWidth during startup. There isn't a table like the 1Gs and Evos have.
The are some other Start Up/Cold Start Enrichment values that can be changed, but I haven't added them to the definition because I didn't see a need and they don't have a user friendly scaling.
With 1150s my car starts in 1/2 a second, with no FP Solenoid and a worn out starter. But if people are having issues, I can add a few more values to the definition to tweak.
running 1000 pte injectors. put the scaling on dsm iinjector scaling nstead of evo. cold start is at around 11-1 and when warmed up at idle is still around there. stft is at 5%. how do i lean it out? if i do lean it out at idle would it affect the whole powerband? am I set to drive like this until I get a tune later? WOT? thanks
If you are not running Full Time Open Loop, AFR is control by the Front O2 sensor at idle. You should be at 14.7 within 30 seconds or so of startup.
DeadTime(Latency) control AFRs at idle.
Injector Size control AFRs at WOT.
5% fuel trim isn't that bad. But you want to look at LTFT.
Hey people ceddy has asked a few times to please not fill up this thread with tuning question and stuff like that so please take all tuning question to this thread, and that is where you ask for help with your tuning issues. http://www.dsmtuners.com/forums/tun...shed-dsm-ecu-98-99-flashing-faq-new-post.html
I've given up trying to keep the thread on topic and just info. I can long longer edit the first post anyway, so all FAQs, Links, Info will be posted on my web site instead of here.
