- Thread starter
- #926
Anfurnyy
Supporting Member
- 1,493
- 1,910
- Jul 4, 2020
Rapid City,
South Dakota
I run 9:1, I haven't done a compression test and it's been awhile since I've done a leak down.To me your plugs just look rich, with the boost you’ve ran on a 67mm turbo with no O-rings I’d say your BALLS are bigger than your problems. What’s your engine compression? I assume your timing isn’t too crazy at 8000rpm, my guess would be valve stem seals on 2 and 3, if you had 2 injectors out of 4 jacked up your AFR’s would show it
Considering your hot start crank sensor issues that might also explain the break up at high boost?
One of the more recent pills I saw 13.5° @ 8000 @ 43 psi, 2nd gear it looks like.
AFRs are a tad rich but it's been cold these more recent logs than from when the car was tuned. So that could be it.
The crank sensor issues are heat related I think but it never broke up due to high rpm or boost, it was also ways shifting or some sort of cut supposedly. Link said that my accel enrichment was a little much coupled with 3% rich during my shifting transition made it possibly rich misfire during shift.
If you look at that video of me doing the 50psi pull I post recently it revs 3rd out just fine after the map limit and "rich" misfire
, you’ve sailed waters I’ve never been in and I don’t mean to sound critical in any way, I just hope you get’er sorted out! You’re cars a ripper
