- Thread starter
- #876
Anfurnyy
Supporting Member
- 1,493
- 1,910
- Jul 4, 2020
Rapid City,
South Dakota
Update time
Since the last update i finished putting the blue car mostly back together. Got the hood re-installed, fuel tank mounted back up, Put the spare driveshaft in the car as well as the big box of parts that the red car came with in it and tied up the wiring engine harness. I dont see a use for any of them for myself so they'll go with the car when/if it sells.
Last weekend I worked my butt off getting the blue car outside. Like i said i had to play musical suspension to get it all moved around. Wasnt fun, On top of that it was raining.
Got both cars in the garage and pulled the suspension off the red car and slapped it on the blue one and rolled it into the driveway. Ill tell you what. WHAT. A PAIN. Rotors are a bit rusty so it didnt want to roll great and on top of that my driveway is slanted downhill. I rolled the car down far enough so it would be on the far side of my driveway and then had to push it back uphill towards the house. It took everything i had to make that thing roll, but finally got it.
Now the fun part, i had to pull all the suspension off the blue car....in the rain. The rears were pretty cake but the fronts took a little bit of time. I obviously didnt want to get wet so I decided to use my full brain and grabbed my tarp and some magnets and stuck it to the car over the wheels i was working over to make a giant umbrella. Worked really well actually! i put a fabric and rubber matt down, with cardboard on top so my butt didnt get wet. Who says adults cant make forts??
Got suspension back on the red car but had some extra time so i decided to put my new hatch struts on the red car. Its the little things, I swear. Now the hatch doesnt have to be held open with a stick or breaker bar or my head while im doing stuff in it AND it actually opens automatically.
Car now belongs to the left side of the garage
Put my old oil cap back on, since it seems to have sealed better.
And FINALLY the oil pan saga has finally come to an end. A couple days after getting the blue car into the driveway i went to work on fixing the oil pan on the red car. I absolutely demolished the old oil pan to get the Buschurs baffle out so that I could save some money and have a fab buddy of mine weld it into the new pan, which is exactly what i did. New oil pan seals correctly. I did rtv the pan slightly differently than i normally do since i didnt want it to leak for sure. Instead of spreading the rtv along the flange with my finger i just left the bead here and mounted the pan for it to squish out wherever it needed to. Seems to have worked. After a couple test drives and driving it to work 2 times last week back to back i didnt see any drops of anything on the ground before leaving or after arriving. #Win
The icing on the cake is i truly think that my shifting issues are resolved now. 3rd seems to shift quite nicely. I havent done any hard 2-3 shifts yet because the alignment is suuuuper goofed but hopefully i can get a few in before the snow starts.
I think i added a 10ga ground to the alternator body > chassis and it didn't make a difference it seemed. I will be added one from my junction block in the engine bay to the engine block though.
