What Turbo is this? [Merged] Turbo ID Identification
nickrule99 said:
A 13g is a TDO4.. hes got a TEO4. The 13g flows a bit better, but the TE04 will have a faster spoolup.
After searching a bit more, Im pretty sure you can just bolt it up to the stock manifold, forget what I said about the t3.
-Nick
My mistake i thought it said TD04, The TE04 is a 13c, off a Dodge/Chrystler
Thank's very much guy's...ill let you guy's know on if im going to use it or not..it's not oging on a dsm i sold that a hwile back...ae86
And so whaqt car model did this come of, i want to take it of to steal the flange.
It looks like you can use the manifold off any of the following cars...
84 Dodge 600
87-89 Plymouth Sundance
86 Dogde Lancer
84-86 Dodge Daytona
86 Chrysler Laser
89 Plymouth Voyager
87 Chrysler New Yorker FWD
85-88 Chrysler Lebaron
Theres a bunch more... Go to www.car-part.com and use a 1988 Dodge Shadow as your car. Look up a Exhaust Manifold, w/ Turbo and you'll be all set. Or, if your hands on a cheap 4g63 turbo manifold, you could take the flange off that instead.
Your going to need to pick up the downpipe flange as well, which you could also take from a DSM.. or one of the above cars.
Good luck :thumb:
-Nick
the teo4h was found on the Dodge Spirit R/T which made 224 horsepower on a four door platform.
The Dodge Daytona, and many others that were listed above. Its limited to about 18psi
mdctalon said:
I Believe it is a 13g turbo found on the 1g A/T cars or a 3000GT
all 3000gts had the 9b turbos, nice try tho... if they had two of these puppies they would have been even bigger monsters... 9b=smallest turbo you could imagine, scaled down by 200%...LOL
390cc: injectors
they have smaller cams too.
13g
i put 450cc in mine and you need to upgrade your ecu by using a gm maf, or like a ecu out of a same yr car (manual car). then it will correct it that way.
i did the gm maf to be safe.
I'm not sure if the auto ecu will work with 390's. :thumb:
Is this a 14b or a 16g? i am about to buy it for 200. is this a scam or not?<img src="http://i23.photobucket.com/albums/b389/skylin35/big16003.jpg" alt="Image hosted by Photobucket.com">
Here is another picture<img src="http://i23.photobucket.com/albums/b389/skylin35/big16001.jpg" alt="Image hosted by Photobucket.com">
We are doing it threw paypal, if it isnt legit paypal will get my money back?, Cmone, quick quick, i am buying now. :D
I would get a pic of the blades under a light. Those pics are useless pretty much as far as determining what it is. Its a TDO5 Housing. If you can get the whole serial number you can look it up by that as to what it is as well.
best i can do<img src="http://i23.photobucket.com/albums/b389/skylin35/big16gpimpin002.jpg" alt="Image hosted by Photobucket.com">
That pic is garbage again. It looks clear enough for me to put foward an educated guess as it being a 16g. Im not too sure what sort of dysfunction this seller has with taking pictures in light but i would still be a bit weary. It's not that hard to put light on it.
Ok here much better
<img src="http://i23.photobucket.com/albums/b389/skylin35/wheel001.jpg" alt="Image hosted by Photobucket.com">
prophecy7115 said:
Ok here much better
congrads on your new 16g :)
YAY!!! :rocks: I feel like i wont the lottery, ok its paypal so its completly ok if he does rip me off right? BYE BYE T-25 :rocks:
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
