Calan
DSM Wiseman
- 7,250
- 400
- Jan 16, 2007
OKC,
Oklahoma
ill load the map that glen put on and take a log, but i shouldent be pulling hard with those timing tables yet correct? im re reading all your posts multipul times to get this into my head
You shouldn't be pulling "hard" immediately on any major change unless you know for sure that you won't see knock. Always do a partial or low-boost pull first after any radical changes just as a quick sanity check...then you can do a full pull if everything looks ok. Watch your wideband and especially for a knock cell as you roll into the throttle. If you see ANY knock or the wideband starts leaning out (probably anything more than 11.5 or so for now), get off the gas and study the log to see what's going on.
I haven't actually looked at Glen's tables yet, but they are probably a safe yet not overly-conservative set of maps that will be a good starting point. They should be fine to run while you dial in your VE table. Once that is done, then go back and optimize his AFR and timing maps for your particular setup.
and the file name is suposed to say after glens.eda log.elg
pardon my spelling
), but for new tuners I think it would be safer to go with what we are all used to seeing on these cars.
