snowborder714
Moderator
- 16,188
- 465
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
Please don't bump your threads. If you need help, send some PM's to people who have helped you out in the past.
1. Your TPS needs to be adjusted. It's at .51v at idle and should be at .63v.
2. Your ISCPosition is a bit high at idle (should be around 30).
3. In your 2nd log, just view your AFRatioEst and wideband during the pull. This will show you (as well as using the track datalog feature) what cells need to be adjusted in the VE table. You can also use either the spreadsheet my brother (turbosax2) created for SD WOT tuning or calan's LinkTools spreadsheet to help do this.
4. The reason the timing seemed a bit aggressive in the Evo table and you're getting knock (2nd log) is that you're only showing a load factor of 1.8, which is still in the high timing portion of the table.
5. I don't see a 3rd gear pull from 2k to redline, so I can't really evaluate WOT tuning.
... so amusing my MAF is calibrated perfectly and my fuel trims are in check i SHOULD be hitting a perfect target AFR in the DA table correct? or if not perfect damn close?
but i did start another thread asking where everyone is finding race gas or 110 oct in northern Washington so i might be switching fuels if i can find something close enough.
it will sound like it cuts out and then i have to get out of the pull... and the logs don't show it to be knock.
