Calan
DSM Wiseman
- 7,250
- 400
- Jan 16, 2007
OKC,
Oklahoma
The numbers in each cell are the amount of ignition timing advance that the ECU is going to apply at each RPM/load point. You will be MUCH better off running on the stock Evo 8 map than you will with that timing table you have now (the one with -8* across the board). With that much timing retard, you are putting way more stress and heat into the motor than you will with a conservative stock Evo 8 map.
Don't do any pulls at all until you get the timing back to normal. You can then do some low-boost pulls while you work on getting the VE dialed in. Don't worry about adjusting the timing and AFR DA tables until you get the airflow calibrated... unless you have knock. If you do, lower the timing cell where the knock occurred by the same amount as the degrees of knock, and then smooth the cells on each side into it by a degree or two.
Set the CEL to come on at 2* of knock, and keep a close eye on it when you start getting into the gas. If it comes on at all, get off the throttle immediately, pull over somewhere safe, and review the log to see what's going on. If you can do a full low-boost pull with no knock, work on the VE table to get airflow calibrated. Then up the boost a little... rinse, dry, repeat.
EDIT:
Damn... I replied after getting home and didn't refresh first. Now I see 132198369861293 posts between what I thought I was replying to and my response.
EDIT:
