mattasi's Eclipse GSX
Mitsubishi Eclipse GSX
K&N filter element / FP Cast aluminum intake tube / Old school FP green turbo / Greedy electronic boost controller / Apexi FMIC and short route steel hard pipes with Extreme PSI silicon couplers and T-clamps / External 38mm Tial wastegate / Tial BOV / Walbro 255 fuel pump / B&M fpr / 660cc Denzo injectors / BJ's polished SMIM / Stock TB / NGK 7mm spark wires / NGK spark plugs / Turbo Back 3'' Megan Racing Exhaust / Megan Racing o2 housing / Balance Shaft Eliminator Kit / RRE Oil Catch Can / RRE Prothane Motor Mounts / Optima red top battery / RRE black silicon vacuum lines
Mods-Engine
6 bolt longblock swap, build by English Racing / Wiseco HD 1400 Forged Pistons 9:1 compression / Eagle H-Beam Rods / ARP Head Studs / OEM Crank / ACL Race Bearings / Head upgraded with GSC valve springs, TI retainers, Chromoly seats, Supertech valves with the 4-angle intake valve grind and the 4-angle radius exhaust valve grind / HKS 272 intake and exhaust cams / HKS adjustable cam gears / Cosmetic hg /
Mods-EMS & Logging
DSM link v3 on Speed Density/ Auto meter Cobalt Boost, Egt, Oil pressure gauges / Apexi Turbo Timer / Innovative MTX-L wideband gauge
Mods-Drivetrain
ACT 6 Pad Spring Race Disk #6224704 / ACT Extreme Pressure Plate #MB010X / Stock Flywheel / Braided Stainless steel clutch line / OEM throw out bearing / Sheppard Stage 4 Transmission, with Evo III first gear and input shaft, EVO III fifth gear, 4-spider center differential
Totika springs and shocks / Megan Racing front and rear strut bars / RRE Front camber correction kit / Les Schwab Rear camber correction plates
Sparco 5pt harness on driver and passenger side / Cross seatbelt roll bar
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Fuel Used : Pump gas
323.7 lb/ft
Dyno Type
DynoJet
Dyno Shop Name
English Racing
Dyno Session Details
Nitrous : No Nitrous
Turbo : Old FP Green
Boost : 26
mattasi
Rating
5.00 star(s) 1 ratings
More in 2G DSM
Share this Vehicle
