JusMX141
Moderator
- 15,147
- 1,289
- Dec 13, 2005
Greensburg,
Pennsylvania
I'm not here to build your setup or guess what spool / horsepower range it will generate. TECHNICAL questions are what I answer- your most-technical question was in regards to the wastegate, which I can't even begin to guess on from the one photos you've shown me of the compressor cover.That's not what I'm a little pissed about. He already got to mine, he just told me absolutely nothing helpful. "The last turbonetics 60-1 I used lasted a whopping 150 miles," that on top of telling me to use the search didn't do much for me.
Correct- but it could be welded shut....in which case he'd be forced to run an external gate off the manifold. A question which would easily be answered with more photos.I can see the internal flapper arm in the photo so at some point it was internally gated, so if its still setup that way your missing the actuator.
. Still my 14b pulled decent at the rpm/speed your mentioning. You deff had an issue.
