Miasma
- 442
- 58
- Aug 22, 2012
Fort McMurray,
AB, Canada
Are any parts between hx35 and 40 interchangeable? Compressor and turbine shaft? Sorry if been asked before
Yes; but the compressor must fit both the cover and the center housing...you can't drop a 60/86 HX40 wheel in place of a 54/78 wheel on a HX35.Mi"sma;153213004 said:Are any parts between hx35 and 40 interchangeable? Compressor and turbine shaft? Sorry if been asked before
Zero personal experience with BW turbos, although the compressor spec is similar to a HX35.Justin, have you ever analyzed the BW S256 NET, here?
38psi. It's mentioned in one of his threads, not sure which one. Would've been higher but that's all the 1200's would allow.
By the way, tracks that play by the rules will throw you off at 11.49 or faster with no cage.
ill tune for 35psi and see where the IDCs are at and just hope for the best. i think im at 88.3% IDC at 28psi
You'll never go that far with 1000's unless the car weighs 2000lbs....that's barely enough fuel to max out a HX35.
Your car being close to full-weight isn't going to be easy to get into the 9's but it's definitely possible.So Justin, I'm at a crossroads of sorts. My goal is a 9 second street car and I had decided that instead of a larger turbo I would drop weight, so i purchased CF doors, hood, hatch blah blah blah. But I have now decided that I am going to a larger turbo for 2 reasons, 1. It will be easier and 2. It should really help with my IAT's at the end of a run.
I'm really looking at FP's 3586 because it would be an easy swap and some have made over 800awhp. What are you thoughts/opinions and is there anything else I would need to bolt this on at the top of your head?
Even by using a bolt-on 3586, the turbine housing is still a confirmed .69 a/r which is a major upgrade to the 7cm/8cm factory Mitsu housing.
Or what about staying with the Red for now? By dropping 500lbs you can potentially put yourself in a very good position to go 9's with the old-school Red given your previous accomplishments although it probably wouldn't happen without a 1.5 60-ft and some really good tires which increases your chance of breaking something in the driveline. I don't know exactly what is the fastest FP Red out there but you have to be close.
.This is from DaveHow so? Red isnt stock appearing is it though? What dsm or evo came with a 20g? With that large of a compressor housing?
Rules seem clear to me but I wrote them. ANY Mitsubishi STOCK APPEARING turbo that came on a 1g, 2g or EVO is legal for the Stock Appearing Turbo DSM class. So yes, FP Red's and Blacks for the EVO can be used on the DSM.Originally Posted by Nate Crisman
yup, and when you combine that power level with a 2400lb gutted 1G AWD with the Automagic trans, it wouldn't surprise me to see the "stock turbo" winning car running faster than the entire DS Eliminator class and able to qualify for Q16.Granted, Im not going to build a car specifically to exploit the rules for one single race event, but the potential is obviously there. Billet 16g's were allowed at last years "tin can-stock turbo" class, so I can't see why the FPblack wouldn't.
Yeah i read that thread, but like i said, the red isnt in any housing that looks stock appearing on any of those cars. Its a 3" inlet for god sake.
