Ludachris
Founder & Zookeeper
- 8,880
- 4,727
- Nov 12, 2001
Newcastle,
California
It's about that time again. Time to start thinking of plans for the offseason. What are your goals and plans for next season? What type of events are you planning on prepping for - road racing, TT, autoX, rallyX? What projects will you be working on in the cooler weather?
I'll be doing more Time Trials stuff. My plans include:
1. Fuel surge tank.
2. Oil filter relocation.
3. Solid motor mount bushing(s) and suspension bushings, as well as some fabricated tubular rear control arms.
4. Some minor body work and possibly paint.
5. More weight removal.
6. Tubular front and rear crash beams (bumpers).
7. Maybe some custom exhaust work for the O2 sensor housing/dump tube/downpipe connections. I'd like to recirc my dump tube into the downpipe and rearrange some of the connections to make more room in that area and cut down on the heat.
8. Ducting for brakes and radiator cooling, and probably another hood vent.
9. Scrape up some cash for an aluminum drive shaft and a 6-8 point roll bar/cage.
10. Larger injectors to run E85.
That's a pretty long list. Let's see if I can keep the garage warm enough to get half of it done.
1. Fuel surge tank.
