- Year
- 1990
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Mods-Bolt-on
- JRC Front Mount, Custom intake piping, Boost Sciences MBC and Diverter valve, FP green, SBR exhuast manifold, and tial wastegate, Porsche 996TT fuel pump, AFPR, 880cc Injectors, -6AN fuel line from fuel cell to rail and back with high flow filter, VRS 02 elim downpipe, Custom 3 inch back with magnaflow muffler and resonator.
Cooling mist water injection,
- Mods-Engine
- 2.0 Liter Ross 8.5:1 and Eagle short block with a knife edged crank shaft. O-ringed
Built head with 1mm oversized valves, crower cams, with HKS retainers and crower springs.
I've got a 2.3 liter 7 bolt with 8.5:1 JE pistons and Eagle rods sitting on an engine stand. and another stock 6 bolt sitting in a corner.
- Mods-EMS & Logging
- AEM EMS and FJO Wideband. Water temp, Oil temp, Oil pressure, Boost, Trans temp, and voltage gauges.
- Mods-Drivetrain
- ACT 2600 pp with 6 puck disk attached to a fidanza flywheel. TRE built GVR4 RS road racing transmission (different ratios). Rebuilt 4 bolt rear, rebuilt transfer case.
- Mods-Handling
- Wilwood 4 piston calipers with a steady supply of Hawk racing pads, 2 piece Aluminum hat 13" rotors, SS brakelines, 3000gt Vr-4 brake master cylinder
Full set of Eurethane bushings, Ksport coilovers, RM rear sway, Full SCCA/NASA legal roll cage
- Parts Wishlist
- 17x9 TD road race wheels.
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Sponsored Car : yes
- Dyno TQ
- 0.0 lb/ft
