- Ownership Status
- Currently Own
- Year
- 1992
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Build Type
- Road Course
- Mods-Bolt-on
- Curt Brown Ported 1G Intake Manifold
Curt Brown ported 1G throttle body with upgraded butterfly
Forced Performance DSM 76HTA dual ball bearing turbo
Diamond Star Specialties FMIC Top Bottom flowing
Forced Performance exhaust manifold Swain Tech coated
Custom 3' exhaust with Borla XR1 Sportsman muffler
Kiggly main girdle
Moroso baffled oil pan
Setrab oil cooler
Setrab transmission cooler/pump pulling from drain and returning at fill
Stoptech Big brake kit
8 point NHRA cage...need to change asap
TIAL BOV and Wastegate
Injector Clinic 950cc Injectors
AEM Fuel rail
034 Motorsport swirl pot with Bosch 044 pump
- Mods-Engine
- Stock crankshaft
Eagle Rods
Ross 8.3:1 Pistons .020 over
Curt Brown Ported head with stock sized valves
HKS 272/272 cams
Fully balanced rotating assembly
Mitsubishi MLS head gasket
- Mods-EMS & Logging
- AEM EMS Version 1
- Mods-Drivetrain
- Quaife front differential
John Shepherd stage 3 transmission
EVO 8 Rear differential with 12 disc option
DSS Aluminum driveshaft
ACT 2600 street disc
- Mods-Handling
- Curt Brown Ceramic wheel bearings
Muellerized Ohlins coilovers
Active toe eliminator
Custom rear upper control arms with heim joints
Full poly bushings including subframe
Delrin moustache and rear subframe bushings
Front and rear strut tower braces
Custom front splitter
custom brake cooling ducts
- Parts Wishlist
- Road race specific roll cage
AIM digital dash
full undertray
