94awdcoupe
- 1,416
- 217
- Nov 6, 2004
tampa,
Florida
No I can make 500whp or 700whp at various backpressures above or below 50psi. It's called turbine matching. An evo3 16g turbine itself flows enough mass for 500whp. A 44mm gate even with a 90* turn added to that is plenty. I've already explained how the 16g 44mm gate will be wide open for anything after the desired boost is reached, you know later in the rpms, when the motor is developing 550whp.
When the 60-1 (2nd gate) opens, that doesn't mean the first one closes. It's set to open at 10-11psi, whatever resulting volume flow is neccesary to get the 60-1 spooling faster. When the 2nd gate opens, backpressure in both turbine housings go down. Yep, the 16g slows in rpms, but who cares the 60-1 is maintaining the boost. Afterall, it's already spooled enough to open the 2nd gate. As well, the 16g doesn't increase in spool speed or take any more energy from the exhaust once its wastegate opens (1st gate). It looses energy transfer very quickly, since the state of the gases upstream of the 16g turbine equalize to the state of the gases down stream of the 16g turbine. Where there is no temp change there's no work done. Eventually the 16g compressor/turbine/shaft is free wheeling. It's done it's job. The 60-1 is on boost.
This is incorrect. here are some pictures to clear it up for you. as I said earlier wastegates do not work to control back pressure. These are pictures of how a 11psi actuator works. I hope we can all agree that external wastegates function the same as internal actuator. 10 psi yields closed wastegate. 11psi wastegate starts to open. but barely. at 14psi it is clearly open but still not by much. it takes a full 20psi before its fully open.
This is because wastegates have a spring in them. as the spring is compressed with boost it takes more boost to open it farther and farther.
so your statemnet that the wastegate will be wide open at boost is not correct. it only goes wide open during momentary over boost.
Lets say you have a 15psi gate. at 14psi the gate will not be open. at 15psi it will be barely open. just enough really to bleed enough exhaust to control the boost at 15psi. the wastegate isnt fully open for max flow till you see 25psi at the cannister. problem is you are trying to run 15psi boost. so it will never be open that far except for momentary boost spikes.
mow what happens when you run 30psi on a 15psi spring? same thing really at 29psi the wastegate will not be open. doesnt open till 30psi. and it wont be fully open till the boost is at 45psi since the wastegate is now being "fooled" by bleeding pressure off.
This is the same reason a larger 60mm gate wont flow more than a 44mm gate. The valve on 60mm will simply be closer to its seat than with the 44mm gate. This is why larger better flowing waste gates control spikes better. they flow better only during spikes when the valve flys open during over boost.
