92AWDHX40
Supporting Member
- 14,519
- 2,744
- May 22, 2007
Kalamazoo,
Michigan
Sweet great progress.
Ok so I paid to have the intake polished which cost me a pretty penny. Now it's dull again. So question. I was talking to the guy that does all of my powdercoating and he showed me so transparent coats that allow the aluminum to show through. So I would just polish it once more then have it coated. What do yall think?
Yeah thats what I've heard. I am going to have it smoked.The coating will yellow over time and you will need to remove the coating.
YeahThe iac/isc/fiav are designed to raise the idle. If your car is idling high with them deleted there may be a problem with a vacuum leak or the throttle body blade not being closed enough or leaking through the shaft seal on the tb.
, I have found the leak. It was the brake booster.
. It came off a trade-in camaro. I have no idea what I'll do with it. I boxed it up. Maybe I'll install most of it on the Galant.
. There is still much to iron out, but I'm making way. She kept cutting off because I can't drive a standard
. no, I have to adjust the clutch pedal. Also the tune is not spot on. I will say this, she is very snappy. It does not take much pedal to get her to move. I have not gotten her into boost yet. Kind of anxious but being patient, and HKS EVC6 is a pain.She rides like a skateboard
, but I do not mind.
