92AWDHX40
Supporting Member
- 13,610
- 1,562
- May 22, 2007
Kalamazoo,
Michigan
Sweet great progress.
Ok so I paid to have the intake polished which cost me a pretty penny. Now it's dull again. So question. I was talking to the guy that does all of my powdercoating and he showed me so transparent coats that allow the aluminum to show through. So I would just polish it once more then have it coated. What do yall think?
Yeah thats what I've heard. I am going to have it smoked.The coating will yellow over time and you will need to remove the coating.
Yeah , I have found the leak. It was the brake booster.The iac/isc/fiav are designed to raise the idle. If your car is idling high with them deleted there may be a problem with a vacuum leak or the throttle body blade not being closed enough or leaking through the shaft seal on the tb.
