Fuel pressure regulation question.
Status
Not open for further replies.
meeklo1569
Dec 24, 2004
toledo, Ohio
Will a B&M commandoflo fpr rise at a 1:1 ratio with boost, or does it just set the base fuel pressure? Thank you i love you
It's supposed to be rising rate, but they're WORTHLESS. You can only RAISE pressure, so if you're going to a larger fuel pump and need to control it, you'll still overrun to hell and back. A proper Aeromotive AFPR with install kit will run about $195 (Import Evolution sells a good setup). You'll thank yourself later.
ok thanx, call me babe.. im back and cali and miss your bod
I think you seriously mixed up this site and IM. What, you can't do two things at once? :p
Anyways, to what John was refering to, click here or here.
Pretty sure (s)he is... no idea who meeklo is. :b
I'd recommend the former link, unless you particularly like the look of SS lines.
Status
