twicks69
Supporting Vendor
- 4,311
- 2,025
- Mar 12, 2004
Milwaukee,
Wisconsin
Detail 1st and 2nd engagement teeth. You can run the 5th intermediate gear as is, or debur it and run it.
Replace 1/2 hub and slider assembly, 1/2 fork, intermediate shaft bearings, 1/2 synchros, seals, shaft nuts, roll pins, snaprings.
Check 3/4 fork wear patterns and 3/4 gearset once disassembled.
Open up center diff, check upper/lower oiling washers and spider gear bores and oiling washers.
This would save you the trouble of doing this ad nauseum and put it all in one place. I'd try to incorporate your responses on things like preload, solder method, tools, how to remove/install various parts, etc. It would be my way of giving back to the site and thanking you and others.
