1g/2g AWD transmission parts??
92EagleAWD
394
5
Jan 7, 2008
Vero Beach, Florida
Ok, so i just got a 2g awd tranny for $250 :hellyeah: but the guy said it would pop out of 4th gear every once in a while, so upon inspection the slider was dirty as hells, and the syncro, and the gear itself both look pretty worn out. Does anyone know if i can use parts from a 1g tranny? like 4th gear? i know some of the gear ratios are different but what can i use from my 3 1g trannies i have? i just need 4th gear, slider and syncro. but i have brand new syncros so never mind them.
You would have to swap 3rd, 4th, the 3/4 hub and slider assembly, the synchros, springs and keys, the shift fork and the shift rail end for 3/4. This is if you have a late 1991-1994 transmission with the same gear tooth profile. You cannot just swap out one part for another unless they are late 1992-1999 as they have the same ratios, gear tooth profiles and synchronized designs. Late 1991-early 1992 have the same gear tooth profile but use the 2-hole shift fork, smaller diameter/thicker hub and slider assembly, smaller synchros, etc. and require the parts I described above.
Tim Zimmer via Evo Phone
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
