1G FWD gears in AWD transmission
whataboutmalyw
Nov 21, 2021
Astana, Asia
Hello all. Would i put 1st and 2nd gears from fwd transmission to awd transmission? I have an AWD with broken 1st and 2nd gears. And i have clear fwd transmission. I want to swap gears between tranny's. Would i do that?
I have plenty of 1/2 awd gears let me know what you need.
I lost my idea to repair transmission cuz i didnt found bearings in my country.
Now i want to replace transmission from KW5M332NQXV to W5M332UMXL.
First transmission have a 3.55 ratio, second have a 3.91. Can i change main gear or some another details to change transmission without changing transfer case and rear gearbox?
No, changing the output and ring gear in the trans requires the matching t-case and rear diff.
Hold up. I think he's asking if he can just do that and not have to get a new tcase and rear end. Yes if tourbring gear is matches to a particular tcase and rear end then yes they are swappable. You need to know what's what and have a complete matching set. Ring gear and output, tcase and rear end ratios all have to be compatible
