What Turbo is this? [Merged] Turbo ID Identification
i know i was joking about selling it here, but there is an ad in classified. thanks for all your help guys
i purchased a JDM engine and tranny. and i was wondering how would i know what turbo came with the engine, any way to find out with out comparing to another turbo.
Most likely a 14b. Look at the fins. If they are staggered big and small, its a 16G. If they all look the same its probably a 14b.
i heard that the kind of injectors that came with the engine might be a factor to figure out which one it is. Is this true?
Don't use the tranny before you do research. I'm in the same boat (cept I got yellow tops with a 16g :p) but from what I've read the JDM trannies have a different final drive ratio.
anyone speak enough japenese to do a search for a jdm tranny?? :D
Gotchicken01 said:
I know this is going to sound like a stupid question, but when you say 16g what does it stand for?
That's the type of turbo it is.
That usually referrs to the compressor housing when someone says "trim" or the wheel 99% of the time.
Big16g is the type of turbo that it is.
Same as 16g, t25, t28, 50trim, 60trim and so on...
Hey
I have had some bad engine problems so I bought an imported 6 bolt through ASAP Motors out of Texas. The turbo's fins are like double fins on the intake side as compared to the fins on my 14b turbo. The #'s on the turbo are TDO5H 49178-01 if this helps. Is this something bigger or is it the t-25? O yeah it also has very little side to side play is this ok?
Thanks,
Chris :laser:
16g is double fined and has a tdo5h compressor housing can you take any pics of it?
I can't get any pics right now but maybe by thurs night i can this motor came from Japan w/ thirty thousand miles on it. The injectors don't appear to be stock either. If this engine was upgraded to a 16g could the injectors be stock or do they have to be upgraded?
OMG my turbo has the double fins too.......xcept it doesnt say tdo5 on it. its a garrett i know that for sure......i thought all the stock turbos came in the tdo5 housing (the 14b and the t25)???? instead of td05 mine says a/r 48m2/ 2...... (im not trying to thread jack, if thats what this would be considered....im sorry) OMG
If the engine has a 16g, the injeectors should be yellow top. They are rated at 510cc and will be fine for that turbo but you will need an afc or some other type of fuel control to use them. Your factory ecu will not run them properly and you will run excessivly rich.
Thanks for the info. It does have yellow topped injectors. Does this mean that it is a 16g or could it still be the t25? Does the t25 still say tdo5h on the housing? sorry about all the dumb ????'s. Is the play in the turbo alright? It's very small amount of side to side movement.
Thanks again for the replies.
It's a 16G. T-25's don't come on a 1G.
are you sure it's a 6 bolt?
here's a pic of my turbo (sorry it's not a great pic, but it's what I have.
Your's should like something like this.
I bought a jdm engine without knowing what it really was, and it turns out it has the yellow tops and a 16g turbo, but it is a 7 bolt... so that's what I'm wondering....
Yeah it is a 6 bolt. I have the engin out now and on the front side of the engine the oil pan curves out instead of in like the 7 bolts. I also pulled the manifold off and took a look at the collector side outlet and its much bigger than than my old 1g outlet. Does this mean that it is and Evo manifold? If so, is it possible that this engine came out of an EVO? The intake is also different w/ space between the runners instead of being solid, and only 1 vacum line on the throttle body instead of 4.
No it would not be out of an evo, reason being that the timing is on the opposite side. It has been said time to time that JDM motors come with a 16g and 510cc injectors. Good luck with your project. :thumb:
