JusMX141
Moderator
- 15,147
- 1,289
- Dec 13, 2005
Greensburg,
Pennsylvania
Not sure on that one- any idea what the compressor specs are?anyone see one of these before?
Mitsubishi Turbo Core TD06 8 Part Number 49593 22501 | eBay
the wheel in the pic is neither. the 17 and 19 had straight blades
Forced Performance Turbochargers: Syclone/Typhoon 17c Turbo
Not sure what you're asking here. Staggered-blade wheels are designed for better efficiency in the higher boost levels. Compare the maps between the Big 16G and 17C, two turbos with nearly identical specs:Although thats a good question for Justin..What determines the staggard comp wheel on mits turbo's? Just the way that turned out or?
Notice that the efficiency islands extend to much higher pressure ratios on the 16G versus the 17C. At 3.2 PR the 16G is still within a 65% efficiency island while the 17C is.....surging.
Madmen,I tell you.
