spoonman
Supporting VIP
- 864
- 33
- Jul 20, 2007
Omaha,
Nebraska
Where does your car stand now? Have you made a pass yet?
Right now the engine and drive train are out of the car because we are swapping them into a chassis that already has a good rollcage and is stripped. The engine is a 2.3 and the drive train is an AWD automatic. The other reason why the car is pulled apart for the off season is because we are upgrading the fuel system, before it was an Bosch 044 with 4x1650cc injectors, now we are changing to a manual pump and either more injectors or larger 2250cc injectors.
So far we have only a few tuning passes (6) but the fuel system is lacking, now the track is closed intill spring. I did not want to give out any times yet but the fastest pass so far is 11.7. We are actually looking to break into the 9.9 territory and demolish Joe's record. I want to have the car making good consistent times by June and I will wait intill the Shoot-Out to make an all out record pass.
The boost pressure will be kept around 19-20 PSI but we will be experimenting with different levels at the track, The compressor should be flowing around 450 CFM's, with air density at .0689 the compressor should flow 31 LBS/MIN. On gasoline that should give you around 300 HP but with methanol 31 LBS can net 370 HP. But this example of HP only uses the the amount of air and fuel being consumed and does not take into account the higher compression ratio of pistons, advanced timing, colder intake charge, and colder EGT's. I believe we can make 400+ HP and the car will have to be as light as possible, hopefully with driver around 2500.
Did you think it would get this crazy? I think there's gonna be about 10 new 14b contenders next year.....and a few that have been at it for a while......
