1990TSIAWDTALON
Moderator
- 13,321
- 11,398
- Nov 14, 2013
Independence,
Kansas
I love my borescope. Very handy
They've become so affordable, it felt silly not to own one. Whilst i love the idea of an articulating head, I couldn't justify nearly double the cost so I went with this one and it works really well. Even comes with the hook and magnet attachmentsI love my borescope. Very handy
keep at it.At this point, if it's at least centered, it should be fine. If not, add a thicker shim.
Whenever I can, the borescope has proven quite useful. That pic was flashlight and phone camera.Are you using the new boroscope.![]()
It's my hope that after a bit of material is taken off the clutch, it'll be in an even better spot, but that's a long way off and I'm not taking anything more than tenths for a good while. There's just no physical way I can get it exactly centered without throwing the dice and going to a completely new clutch. I don't think even taking 2 thousandths off the flywheel surface to increase step height is going to magically move that fork end into position. You can see how much gap there is between the TOB and pp fingers for a centered fork end. It must be the fork geometry itself.I think it will be ok where it's at, it's not ideal but I think it will function correctly.
Indeed, just didn't want to drop the trans each time but I recall reading somewhere on here that it's possible to shim without dropping.I've never noticed any difference in the starter plate thickness. It's not super critical. Once it's running test for clutch drag and go from there.
damnit.
