spyderdrifter
- 5,434
- 864
- Jul 11, 2009
Somewhere in,
Colorado
Yes, I know there are MANY posts regarding this, but not every situation is the same. I'm looking for thoughts, not necessarily answers. I've gotten my spyder to the point of start-up. However it will only crank.
Mods/parts are as follows, but also posted in the build thread:
6-bolt bottom end
2G head
OEM crank
Eagle Rods
Wiseco 9:1.0 pistons
Kelford 272 cams
HKS Cam gears and timing belt
New Gates timing tensioner
No balance shafts
FP Turbo and manifold
I think that's it for the parts that could potentially matter. Aside from Walbro 255 pump. I'm simply just trying to get the engine to start. I've double checked fuel and spark, and tested the 1G CAS. It's all functional as it should be.
I did a compression test a week or 2 ago and got low numbers. My assumption is that's because the engine has never fired up, and therefore the rings have never seated. Am I correct in thinking that, or completely wrong? Wet test did yield slightly higher numbers, but not by much. Service limit for a 6-bolt is 121psi I think, and my dry numbers where 125 to 130, and highest wet I think was 150.
The short block was initially built in 2018, and just sorta sat for a couple years sealed away, and then built the rest in the beginning of 2021, then again sat around until last year when I got the Spyder. Could the compression numbers be this low purely from sitting for years without running? Should I just pull the engine back out and replace the rings and rebuild again?
I'm being patient with this since I haven't messed with these cars in a few years, but it's still frustrating.
6-bolt bottom end
2G head
OEM crank
Eagle Rods
Kelford 272 cams
No balance shafts
