Do not cold start spyder
Dsm2g15
45
Oct 28, 2021
México, Texas
No arranca frío It does not start cold I have to add clin charcoal to lose it and when cold it fails as if there will be a lack of gasoline I have already changed the pump and the filter the scanner does not tell me anything I am going crazy:confused:
Perhaps a leaky fuel pressure regulator (so fuel pressure is not maintained in the fuel rail for days like it is supposed to)? What year/model/engine do you have? If a 2g turbo the FPR is on the driver's end of the fuel rail.
spyder gs 2.4 all stock only makes it cold I have to fill it with gasoline so that it ignites in the throat and it moved the tps disconnect the oxygen sensor why it made me more failure but connected brand fault that tps could be badly calibrated some bacio the iac?
