rag1983
57
Sep 20, 2004
Portage, Michigan
This build took place at a shop called Strictly Performance - which has since changed ownership and no longer works on these cars. You'll notice references to the shop in this thread, as they originally posted a lot of these photos here on the site when they were a supporting vendor, along with info for the build.
Here's a few shots from this past fall with the final mock-up before heading off to paint...
AND NOW...
Just got dropped off from paint, and it's looking fresh! Now it's time to get this back together!
Here's the updated run down on this build...
The Short Block
STRICTLY BUILT 4G64 LR
Manley I beam rods W/625 Rod Bolts
Manley Extreme Duty Pistons with HD Wrist Pins
Stock 4G64 Crank
ARP Main Bolts
ACL HX Main and Rod Bearings
Full Balance/Blueprinted Short Block
The Cylinder Head
STRICTLY BUILT Stage 2 Cylinder Head
Kiggly Race Beehive Springs
Kiggly HLA Regulator
STRICTLY SS Valves
Viton VSS
K272 Cams
STRICTLY Stage 2 P/P
Revised Lifters
ARP 625 Head Studs
The Chassis
Feal Suspension Coilovers
Prothane Bushings
STRICTLY 2g CTS-V Front Big Brake Kit
Tubed Front RAD/Intercooler/Head light Front End Setup
Solid Engine Mounts
Stitch Welded Front End
The Bolt ons
TRE Stage 3 Trans with 4 Spider
STRICTLY Custom FF Manifold
Treadstone TR1245 FMIC
ECMLink V3
1/2 Koyo Rad
FIC 1650cc Injectors
Walbro 450 FP
Aeromotive FPR
Precision 6062 DBB T3 Turbo
JMFAB Intake Manifold
S90 70mm TB
Now it's time to get this thing back together!
Now I understand the radiator placement, looks awesome when all assembled.
Forgot to ask, is there a fan on the bottom as well for the radiator, or are you creating some type of ducting for it; unless the velocity of the air will naturally flow into and under the engine?
We have 2 10" fans with a shroud mounted on the back side of the radiator. We also have custom sheet metal ducting for the whole front mouth section that seals it all up very nicely.
If/when you get that bolted up I'd like the see the finished product, sounds like a lot of thought went into it (love it).
Edit:
Another question, I'm now trying to understand your thought process on the coolant lines... I've never seen it configured that way.
I am literally at a loss for words... everything that I somewhat tried to imagine is literally right in front of me. I am impressed :applause:. Would I be correct in saying that it will retain the factory/aftermarket heater core coolant lines?
I was nice to come by the shop and hang for a bit, that is going to be one sick dsm when its all said and done.
I like the coolant pipe mods... I was planning a modded coolant pipe on the 1g build to change the routing. It was going to elbow down almost immediately after coming out of the water pump, with AN fittings provisions for the turbo and the wastegate. Your execution is better than mine.
Is that an 3g MR2 power steering reservoir? That's exactly what I had planned to do as well - create more space ahead of the motor for cooling and ducting, while upgrading the power steering system at the same time. The more details I see on this build the more I like where this is headed. Curious to see how you address temps on the header.
Kevin I checked out the car a while back, and now I saw it last week at the shop its looks really nice up close its, one sick build I cant wait to see it finished.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
