- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Mods-Bolt-on
- FP Manifold, 3 inch turbo back exhaust, small 16G, hallman pro rx bc, vrsf fmic, hks ssqv2 bov, k&n filtercharger, injen short ram intake, ss full clutch line, ss oil feed line, ss gas fuel filter to rail, aeromotive fpr, koyorad aluminum radiator, onorthodox full aluminum pulley set, cruise control delete cable, battery relocation, wire tuck, stm egr block off plate, brake line tuck, PTE 880s injectors, coil on plug setup, high temperature silicone radiator hoses, 1g intake manifold and 1g throttle body with FIAV block off plate, prothane motor mount inserts, walbro 255 high flow fuel pump.
- Mods-Engine
- fully built 6 bolt head, ported and polished, decked with crower springs and retainers, 3g lifters, Delta 272/272 cams, stock 7bolt block.
- Mods-EMS & Logging
- autometer volts, boost, greddy turbo timer, air fuel, pyrometer gauges...
- Mods-Drivetrain
- B&M short throw shifter, shifter bushings, ACT Streetlite flywheel.
- Mods-Handling
- front slotted rotors, konig rims, evo rear rotors, evo rear caliper upgrade, adjustable coil overs.
- Parts Wishlist
- HKS cam gears, jmf smim, dsmlink, megan racing full coilover kit, FP green turbo... hopefully new paint job lol
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
