We're on Boost
- 3,047
- 1,468
- Aug 25, 2007
Seattle area,
Washington
The cheapest multimeter I know of that is actually good is the INNOVA 3320.
I have one in the garage that I use a lot and it's been reliable and accurate for years.
It's good to have a Haynes manual. I just used it to check on the 4.7 volts thing. Found it right away by finding Coolant temperature sensor in the Index, going to the page, and there it was. It says there approximately 4.5 to 4.9 volts. You can still buy them new. It would be the Haynes #68030. You can order them from O'Reilly or from Haynes directly. Either way it would cost about $40 after shipping is added. I think from O'Reilly it's a buck or 2 cheaper. I can give you links to those if you want. Almost everybody else selling them is selling used ones.
. I haven't been able to check but will chick by not using the plug. I won't have a meter & can't get one ATM. Hope everyone is having a great weekend! Hopefully it's the plug itself. If not I will be buying a meter next payday
