We're on Boost
- 3,047
- 1,468
- Aug 25, 2007
Seattle area,
Washington
Ok yeah those timing numbers are what I'd expect for the stock 1g.This is what the TmngMaxOCT is currently at when I opend it.
Your 20 degrees at 1150 rpm idle, if your load factor at the time was either 0.5, 0.6, or 0.7, that 20 degrees would be right on correct per the chart. So that's probably correct, but you'd have to have Load Factor turned on in your logs to look it up for real.
But I see your Target Idle speed is 850 rpm. So in that video (idle not surging) it's still messed up a little because it's at 1150 rpm with 0% throttle. You'd expect it to be at the Target idle of 850 with 0 throttle if the engine is warmed up. That's why we need to display Idle Sw (idle switch) in your logs. And we need Coolant Temp working. Idle Sw will show either a 1 or a 0 in your logs. A 1 when it's idling. A 0 the rest of the time. It's a physical switch on your throttle body and it tells the ecu that you want it to idle. If your physical idle switch doesn't work there's a workaround, but turn Idle Sw on in your logs first so we can see if it's working. Display TPS Volts also.
Since your Coolant Temp in these videos isn't working yet, we don't know how warm the engine is. If these videos were shot on a cold engine during warmup, that would throw some things off too.
