dsm-onster
DSM Wiseman
- 8,592
- 131
- Jul 11, 2004
Bloxom,
Virginia
Properly slipping and feathring the throttle is imperative with launching in FWD. This mean LOTS O'HEAT! My two street style performance disks didn't last long. ACT and Competition Clutch. Which clutch disk is he running? You'll probably want to look into a high heat capable disk. A quality 6 puck center sprung would do the trick.
This will fit the bill: 6 button E-Z Lock (sprung hub) clutch for Mitsubishi Eclipse
There are others of course.
Again, a clutch is not neccesary but the high heat and hard slipping required for good 60 ft times will severly shorten the life of even a street performance disk. Your slipping action at the pedal will change and the clutch will be more "finicky" or "sticky". But, It WILL slip when you want and hold when you want.
. I don't understand what you would do to the joints to cause more weight to rest on the front? Does it involve manipulating the upper and/or lower shock joint?
