- Thread starter
- #326
turbosax2
Moderator
- 4,485
- 682
- Nov 19, 2006
Mechanicsburg,
Pennsylvania
A few of the lobes on my cams had tiny rust spots. I sprayed them with WD-40 and used a fine scotch brite pad to clean the spots off. Then I sprayed them down with brake cleaner.
Cleaned the cam journals with brake cleaner on a rag, then lubed them up.
Make sure the engine is somewhere BTDC, then rest the cams in place with the dowel pins up.
Cleaned the cam caps with brake cleaner on a rag, then set them in place. MAKE SURE you put the cam caps back where they came from. I also kept all the bolts in their original positions.
Almost forgot the cam seals! Coated in white lithium grease, then slid right on the cam by hand, no tools needed.
Torqued the cam caps down. Make sure you torque them stepwise (increasing torque increments) and in the proper order.
I forgot to mention that before I installed the cams I filled the engine with oil and primed it by spinning the oil pump with my impact. I checked for oil at the head, turbo oil feed line, and I took off the oil return line to verify oil was going through the turbo. I primed it again after putting the cams in. No leaks have shown themselves yet
As usual, I made less progress than I hoped for. It's been too cold to paint, so I put that off for now. I'm still in the process of powdercoating the cam gears. The prep work on them is crucial and very time consuming.
. No really, you guys do a good job. I just purchased my Race intake manifold from Magnus. When i bring it to you, i'll tell you everything i had to do to get this thing. I want to get that coated for sure. I'll bring my TB and show you how that turned out as well.
It's cool, he's still a powdercoatin noob!
