- Thread starter
- #351
turbosax2
Moderator
- 4,485
- 682
- Nov 19, 2006
Mechanicsburg,
Pennsylvania
i see grime on the VC!
Don't worry, I've got a powdercoated one
This thread is EPIC. Amazing! Subscribing!
What kind of wiring will you have to do for the saturn alternator?
Thanks! I haven't decided for sure but I plan on running a 1/0 gauge wire from the alternator to a 200A circuit breaker to my kill switch. And the plug to the alternator uses a switched 12V and one of the 4 stock wires. The other 3 were removed from the harness already.
keep up the good work
I'm now working on the fuse box harness. First I need to mount the fuse box. I found a good place for it so I'll show that once I make mounting brackets for it. Then on to redoing the wiring on the harness.
