Tony20tgen
- 0
- Jun 4, 2010
Miramar,
Florida
Whats up Kevin, Im a fellow follower of u and paul. I have a compound turbo kit project swell. Please check out my build thread. I really learned a lot from u guys and ## thread on yellowbullit has been instrumental in figuring out my kit. I have a T3 57 trim with .48 ar and stg 1 exhaust wheel, and a gt4202 with 1.05 ar split T4. I am going to use two wg tubes off the collector instead of 1 due to collector could not be posted for the 60mm tail wg. As it sits now I only have 1 40mm tube off the collector. Check out my build and hope you can cheer in on our forum.
Tony20tgen Stage 3 build thread - Page 25 - Genesis Forum: GenCoupe Hyundai Genesis Forums
By bolt on, I mean...fabricate, build, text, and cross fingers for everything else
Thanks again for all your help, both here and on HRCS.
. If paired with a t25 would the holset reach full spool before 3000rpm? Twin scroll would definately be easier than compounding especially since people already build twin scroll manifolds and there would be less space issues.
Being able to use the bed makes rear mouting make even more sense IMO. Room for a standalone oil system, AW intercooler, air intake/filter up off the ground, etc. Several drag trucks have done rear mounts recently for these reasons. You could do the same with a trunk/hatch of course but then it's all inside the car.
