- Thread starter
- #651
99gst_racer
Moderator
- 12,010
- 1,706
- Apr 5, 2003
Coloma,
Michigan
Well I waited patiently for the dyno results. And I officially not impressed. Thats not fast spool for 600whp. My 2.3 35r makes 600who by 5500 rpm and holds great power to 8000 rpm. and my setup sucks compared to some evos I have seen. Local here made 580tq at 4100rpm on his FP black setup that makes 600whp dynojet. Stock unbuilt 2.0 evo block. I was really looking to eat my words but I guess I dont have to.
How do you know how fast the spool is without seeing the datalog?Well I waited patiently for the dyno results. And I officially not impressed. Thats not fast spool for 600whp. My 2.3 35r makes 600who by 5500 rpm and holds great power to 8000 rpm. and my setup sucks compared to some evos I have seen. Local here made 580tq at 4100rpm on his FP black setup that makes 600whp dynojet. Stock unbuilt 2.0 evo block. I was really looking to eat my words but I guess I dont have to.
Super jealous!And I officially not impressed.
Whoops! Throw in the towel, boys. The official decision has been made.
21 years after the DSM came into production and we are still seeing innovation. I can't wait to see future setups with different turbo combination. It would be nice to see GT4202 power with quick spool!
This setup has not yet produced a superior power band to a well setup singles that i have seen.
^^^ So where's your dyno sheet or the local's making more torque sooner than me? I seriously want to see them. By all means, back up what you claim.The whole purpose of using two turbos is to gain a superior power band over a single setup. The twin setup is three times more complex, three times the weight, three times the cost, three times less reliable. You better be getting something for all that in return.
Also Paul, you sort of mentioned it, but I don't think enough emphasis was put on it.And while you're digging up those dynographs, here's a few to peak at. These are all from guys using a larger turbo than myself, and making more power than me, but making far less in the lower RPMs. Compare the torque curve of any of these Dynojet graphs to mine in the 4500-5000 RPM range.
BW S362, 628HP, 539TQ: http://mitsustyle.com/forums/attachment.php?attachmentid=8438&d=1239503864
BW S300SX, 658HP, 587TQ: http://i25.tinypic.com/2whds1u.jpg
BW S362net, 691HP, 630TQ: http://i91.photobucket.com/albums/k302/mxguy1286/IMGP0447.jpg
7076, 690HP, 485TQ: http://i103.photobucket.com/albums/m153/bluemeanietsi/cagepaint/SCAN0004.jpg
This isn't innovation this practice is called ''step turbocharging'' it's in many other power plants in industries around the world. The word compounding is more dealing with power being transfered back into the crankshaft then the latter.
Carry on.
Good point. We tried the first pull from 3000 RPMs and the traction and clutch issues were much more pronounced. I really wanted to show what this set-up would do from a much lower RPM starting point.Also Paul, you sort of mentioned it, but I don't think enough emphasis was put on it.
You started your dyno pulls at 500-1500 rpm later than those other dynos makes the torque curve you put down MUCH more impressive. You started at ~4000 RPM and torque came in immediately. They started much earlier giving the turbo much more time to light before hitting the 4000-5000 rpm range, putting your dyno at an immediate disadvantage in that area.
The 60-1's gate has an open upper port to reference atmospheric pressure, and it's side port sees only the boost pressure that it's compressor makes on it's own. The 16G's gate references the inlet pressure that it's compressor inlet sees (which is the output pressure of the 60-1) at the upper port, and it's side port sees the overall boost pressure exiting the 16G's compressor cover (which is 47 psig + IC pressure drop). It's much more simple than it sounds.Where do you have your the lines to your wastegates running to? Intake manifold? Or somewhere on the charge piping?
No, not at all. My IC piping route is about as short as it gets. It's based off of the SBR kit. I'm still using the original SBR core and lower IC pipe, but I've made my own upper.And I take it short route intercooler piping would be a no go huh?
Thanks, man. I garuntee we'll all start seeing much more compound turbo cars popping up in all sorts of different car communities over the next few years. It works very well, and where there's a will, there's a way.Congrats on making such a killer setup man, I can't believe people have the dyno sheets and spool times and are still questioning the effectiveness of a compound setup. Keep up the amazing work!
Thanks man. Yeah, this is the first time I've had this set-up on the dyno. I don't doubt one bit that it would have been in the 680-700 WHP range with a more capable clutch. Using the beginning of the power curve (before the clutch let go) and using datalog data, this is how I would have expected the higher RPMs to look with a stronger clutch:Those results look very promising, id love to see the final result after the clutch and etc. Is this the first time that set up has seen the dyno? From reading the results thread, you guys think you can still pull 700 from this set up?
Ive seen a similar set up ran on a cav back in the day with poor results. Also seen a turbo/supercharger combo that had similarly poor results. Those cars were the only thing i had to base my opinion on.
So far this blows them out of the water, very nice for the first round.
Show me a T6 1.32 AR S475 spooling this quick without nitrous. Show me one spooling at all on a 2 liter for that matter. I'm leaving the line at 5700 rpm and 30 psi for reference. I had to pedal it a bit because the starter was holding the tree for me, it will spool faster at full throttle. I have no problems leaving on a pro tree.
I don't have to deal with the drivetrain issues that come with the added torque so I'm free to keep wailing on the setup and making passes. I haven't found one disadvantage yet to this system, aside from the space it takes up when I want to pull the transmission. Hardly anything to cry about. There is also no weight penalty for me, the 50 trim weighs about the same as the nitrous setup did.
I've been on this setup for two race seasons now and haven't touched the setup at all, it just works. I will start with my dyno graph. I dont have the last best tune in graph for you so I will have to extrapolate a bit for you from 4 year old graphs. We were having boost and fueling issues on the dyno. it left dyno with tun incomplete.
The first graph shows three things.
1. this is third gear pull. 90mph is 8200rpm for my car. 23.4 inch tires.
2. boost was 30 climbing to 34. this is all we had fuel for. and we limited boost on spool to limit the torque.
3. at 34psi i was making 560 at 8000rpm. and this is with my 2.3 with a cyclone intake!. notice pauls 2.0 is falling hard and only making 500 with a 2.0 and sheet metal intake and ###### bigger cams.
second graph is to show RPM and actual spool. again in third gear. on the street with more load we saw 31psi at 4000rpm in the aem logs. The tune was cleaned up and dialed in to 37psi on the street. dont have a dyno graph of finished tune.
1. no boost limit on spool. 600hp achieved at 5500rpm. 500rpm sooner than paul. and it holds it better at redline.
2. fuel curve chopped because at 6500rpm we were at 13.8 a/f. I let off throttle on that pull and run was aborted.
3. as i said earlier my car was built 9 years ago and sucks by todays standards. it has small cams because i like a 750rpm idle. it has low compression 8.5/1. uses a t3 adapter to bolt 35r to cast manifold. turbo was 900 new. 150 for tail gate. 200 for fp manifold. 93 octane and meth injection. cyclone intake. I could go on.
4. paul hits 600hp at 6000rpm, and drops to 500 at 8000rpm. jerrys hits 600hp at 5500 and holds 560 at 8000 with only 34psi.
5. I have seen numerous people on evom embarrass my curve. but for sake of this debate. I will take my single turbo setup over your twin turbo setup.You must be logged in to view this image or video.You must be logged in to view this image or video.
