94awdcoupe
- 1,416
- 217
- Nov 6, 2004
tampa,
Florida
Let's put a 2.3 or 2.4 in Paul's car and see if your car still holds up in comparison. I'll make it easy for you. It won't.
well known a 2.3 spools faster but does not necassarily make better power at high rpm. pauls at 42psi manifold and only 600whp. power at 500 at 8000. what do think would happen at 8000rpm with a stroker in his setup? I dont find your statement adding any intelligence.
has anyone heard the manifold pressure is the boost not getting through motor? this setup is classic example of why that statement is important. this setup has to make all its power through a td05h turbine and a wastegate hole bored through the stock exhaust manifold. I stated waay back that would be a problem. and it clearly is. thers is a lot of back pressure in this setup. switching to a 2.3 will make it worse. it would have more power sooner but far less up top. its harder to get broad power band on 2.3 than it is on 2.0.
here is another graph that is far prettier than pauls and mine. there are likley 10 of these FP black graphs on evom.
. Exhaust backpressure will be through the roof at high rpm. A compound setup will wastegate all that backpressure.
