My 600HP DD build by me and the Co-Workers at Strictly Import Motorsports
TofastForU_99
781
10
Mar 1, 2009
Kalamazoo, Michigan
The project-------- 97 Eclipse GSX
A huge thanks to Strictly Import Motorsports (www.StrictlyImportMotorsports.com and Jeff for the Powder coating at Jeffs Powder Coating
Goals 600HP/11 sec 1/4 mile at least.......
The plan
ENGINE:
BUILT by me and Strictly Import Motorsports
6 bolt block
Balance shaft Eliminator kit
Bored .020
Decked
EVO 9 .20 over pistons
6 bolt rods
ARP main/rod/head bolts
HEAD:
6 Bolt head
Ported Polished and Knifed by Strictly Import Motorsports
Super tech springs/retainers
Viton valve seals
back cut stock Valves
SIM 275 CAMS
Drivetrain:
Stage two SHEP Transmission
Fidanza Light weight flywheel
ARP Flywheel/Clutch bolts
ACT 2600 clutch
Exedy EQUAL slave cylinder
SHEP transfer case
LSD rear
SIM Raceline Racing Axles
TURBO/FUEL:
Holset HX35
BEP housing
FP RACE Manifold
Extreme PSI oil feed and return line kit
Aremotive A1000 AFPR
FIC 1000cc Injectors
Walbro 255 Fuel pump
Tial 38mm Wastgate
HKS SSQV3 BOV
Punishment O2 housing recirculated back into 3" exhaust
ETS FMIC with 3 inch ICP
Engine Management:
DSM LINK V3
AEM Tru Boost
AEM UGEO
Suspension/brakes:
Eibach sportline springs
KYB GTR II shock/struts
Prothan Motor mounts
Prothan front and rear bushing kit
Big brake kit
Drilled and slotted rotors
Hawk pads
MISC:
COP Setup
Tuned to E85 for daily use, race gas on the drag
All Felpro Gaskets
Roll cage
Battery Relocated to trunk
ALT Relocation
Gates racing timing belt
Gates Racing ALT Belt
Gates racing Radiator hoses
Alum Radiator
EGT block off
Alum spark Plug Cover
Cosmetics:
Rear wing eliminated
VIS stock CF hood
black 18 inch rims and tires
CF front lip kit
8000k HID's
Black window tint
tail light black out
new license plate :)
I will be Posting Pictures very soon and will be updating project on a normal basis. currently are in the process of removing the 6 bolt out of the car to put in the almost finished built 6 bolt. I'm looking to have the car finished by the end of february and will be running the car at the 18th Annual DSM/EVO Shootout At Buschur racing also plan on putting the car on the Dyno. Wish me luck and any input will be helpful.
trust me im just as curious. I might actually have it on the road I have about an hours worth of work yet but it is like 35 degrees out today. I swear it was like 70 degrees for the past two weeks then I get my car out of the shop and the weather SUCKS. just a little of my luck.
But I did start it up yesterday again. Idle is 8-850 Rpms it is so smooth and sounds great.
Hey man, just got your VM last night (AT&T's visual VM blows). Sounds like you got it figured out though. Sorry for the late response.
Yah I know VM sucks but hey thanks for the help.
And here is a little treat i guess I ran out of daylight and can you believe it was SNOWING :cry: but is supposed to be nice tomorrow so ill fix a few things and drive it :hellyeah:
here is a video nothing spectacular and I have a little lifter tick under the hood but Im sure it will go away when I get the good oil in it.
And a couple questions to you guys. My coolant temp sensor reads 316 degrees F I have a 2g pigtail and 1g Coolant temp sensor do i need to change it out or swap the connections?
here is the video Ill get on with it driving tomorrow
YouTube - First start up 97 eclipse gsx
1g and 2g coolant temp sensors read different. Yes that is a problem. I am suprised you got it started then. When I did my 6bolt swap to my brothers 2g car, it wouldn't fire with the WAY off reading 1g sensor still plugged into the gooseneck.
So should I invert the wires or install a 2g Coolant temp sensor?
I don't know about inverting. I just swapped in the 2g neck which had all the right sensors and it fired right up for me. I could never get my 1g to fire without the coolant temp sensor plugged in, so I figured that was the problem. Yes the sensor was reading WAY off with EvoScan just like you. Once it was swapped the sensor read fine. So that is the conclusion that I drew: the sensor was wrong so the logger recorded a wild number and ecu wouldn't allow the motor to run.
well I moved the car today :) even if it was 6 Feet backwards and 6 feet front wards LOL. I swaped in a new 2g Coolant temp sensor. My front o2 sensor is still messed up. interior is complete with all panels installed. I turned the CAS 180 and this thing starts on first start now. Whats left is fix Small coolant leak. Change oil, and fix O2 sensor and go for a test drive.
:pray:update on the car. I am entered and runing at the Thunder Natinals may 7-8 at US-131 Martin ill be sure to get some vids.
Problems with the car. Slave cylinder took a crap, exhaust rattle that is annoying as hell LOL, the car is so stiff due to the cage and suspension,
I just got all my new T bolt clamps and black couplers. along with my new ECU back from STEVE thanks man you saved me a lot.
I will be installing my SS clutch line and my new Exedy slave cylinder i have to do a clutch Adjustment and re-torque my head studs. and another oil change.
Here are some more pictures I took it and gave it its first bath today how does it look?
AND YES MY CAMARA STILL SUCKS:cry:
someone needs to come do a shoot for me :pray::pray:
Good luck at Thunder Natinals!! Cant wait to see the vid!!
thanks man
A little info on the event is its a pinks all out racing style friday we have 2-3 runs then they pick a feild of 16 or 32 with closest ET's depending on turnout so i hope ill be apart of that feild then it'll be heads up racing and winner getsw like 1000 bucks :thumb:
wish me luck
Yah let me know if anyone wants to go. if we get a few ppl maybe even cruise out. I have passes for ppl that want to go. A couple of my other freinds are runing we just got done building a KA 240 with eagle Wisco and a GT35R that will be runing around 25 PSI on DR's its pretty nasty ill be trying to keep up with that all night LOL.
Looks great, nice gymkhana rims, now you need like a 800fps camera and capture some launches.
I was waiting for someone to say that. you wanna provide the camera? LOL
hey throw some bucket seats in that car! would look sick behind the cage :)
I second that I just ordered my 5 point pink harnesses and im working on a deal right now. ill shoot some pics when i get it all and instal them
Closest camera I have is a Vx2000, but thats about good enough for skate videos.
Might have to contact Ken Block about that $50,000 camera we need.
Also, just wondering, what are requirements for inspection at Martin?? Do you need a kill switch??
Its been too long, bout 4 years ago Inspection was a "Car rolls straight, shes good" Type deal. Hah
Yeah, just peeked at there website, Ill just put my battery back up front when I go.
I will be using hoosiers up front, depending on what I get from my 16G @ 18psi, I think Im in store for an awd swap..
Wont you be needing a 4-point soon then?? viper? hah
I think I heard you were in a 100mm stroker crank dillema? Thought you told me stroker was a no-no hah..
Im sorta iffy they wont last long, i heard 6 months on a 7500 rev limit, blew a couple up.
