600hp cheap head build
jpmxrider489
2,415
152
Apr 4, 2010
pittsburgh, Pennsylvania
So I got a set 272/272 regrinds. But I found out that I have to use shims. So would I need to get 3g lifters and different springs or can I just get the shims? The stock head can go a far way. I only plan on reving to 8500 if that on my hx40. I heard that manly springs are pretty good and can go without there retainers. So whats you guys think?
How can you replace cams with out haveing to re do the timing???
Well you could try this
RRE Web Cam Installation Instructions
it is reviewed here
Removing Head without doing the timing belt?? - Club DSM Canada
With that being said I would side with bryanwheat and just redo the timing. It is not that hard and you know the tension is correct when it is back together. Also, I would want to recheck the timing marks with either method, so you would be half way there if the timing belt was taken off.
That is all I could think about during the entire thread. If you are currently running a 16G, I would not worry about upgrading the cylinder head. Like others are saying, I would suggest pulling the head and taking to a machine shop. Maybe find a machine shop that will show you the ropes. It is a scary thing to throw "unknown brand" springs and "He said HKS profile cams" in your car. To be honest, hold off and wait until you do the build with the HX40 and plan on the car having a bit of downtime to get it right. I think tearing into it at its current state is going to end up costing you money. On the other hand, we all have to learn somehow. I took the "wing it" approach before I attended college. Just plan on making mistakes, plan on a little extra money, and another vehicle to drive... just in case.
Matt
