Imback
Freelancer
- 1,421
- 538
- Nov 8, 2006
Long island,
New York
What exactly do you want measured justin?
That's fine, I don't expect you to put an expensive item on the line for warranty like that.i'm not planing on taking this turbo apart because if something happens to it i don't want fp to be telling me that the warranty was void because i took it apart or some bs like that.
I wanted to know if the inducer / exducer was the same as a MHI TD06H seeing as no TD06H turbine could ever fit behind an Evo III-style turbine housing unless the housing was cast specially for the larger turbine wheel.What exactly do you want measured justin?
Right...I really think it looks like a smaller version of a HX40 turbine; which is a good thing- we know the HX40 turbine flows a TON of air.It doesn't look like that turbine in the link you provided.
The 68HTA is still a 100% authentic Mitsubishi turbo with an aftermarket billet compressor wheel. Don't let anything said about the FP Green steer you away from the 68HTA.I was looking to get the 68hta, but im wondering now!!
Compare blade shape:
You must be logged in to view this image or video.You must be logged in to view this image or video.
...than a MHI TD06H turbine- yes, we know this.Blade shape is completely different.
FP does not use CHEAP EBAY PARTS.
They have outsourced MFGing of some of their wheels to places in taiwan for casting. They maintain very strict material standards, it's just more cost effective over seas at the moment.
this is why are economy is in the pits, put Americans to work, build and mfg in American!
Not even close, really.That turbine wheel looked familiar... so I went out in my garage...
FP HTA3076r
Thoughts?
The turbine looks like this. Turbo Turbine wheel Mitsubishi TD06H 20G turbocharger - eBay (item 320543830786 end time Mar-02-11 04:57:45 PST)
The real td06h turbines have 12 blades anyway. Not saying it's china garbage, and it will not last, but it's not a mhi turbine, or turbine housing. It is an evo3 style housing, but there wasn't ever a lip in the inlet. it was cast pre ported.
