- Thread starter
- #26
AWD-Tony
- 6,787
- 3,748
- Sep 11, 2017
Cincinnati,
Ohio
I’ve been searching but I can’t find it. Does anyone have a part number or link for the smaller diameter oem slave cylinder?
As a test, you could reach in through the fork window with a modded 14mm wrench and back the pivot ball out maybe 2-3mm
then feel the pedal and see if its what your looking for. dont drive it this way , but then at least you will know what you need to do.
Can you cut a washer just enuf to go under the pivot and slide it in like a front end alignment shim?
I'm curious about this. If the hydraulics are free to self adjust then it is not physically possible to gain travel by moving a piston. For all those reading consider this. How about an air bubble at the slave?Would it react differently if it were in the slave vs in the small line?
This reply isn't meant to dispute what you are seeing. It's meant to understand why. Everything I know about hydraulics and physics says what you're seeing isn't possible. There needs to be something else to help explain. Would you agree?
I'll try my best.Yeah I agree. I can't explain it.
. One could simply use some springy 2-3mm diameter wire (316L?) formed around a 14mm bolt with a torch into a circle then that would go around the base of the ball and slide it down onto the pivot ball threads.@GST with PSI you have it mostly correct. What happens when you change over to an extended slave rod is you bottom the slave piston out in the bore and that rod actually pushed a little on the cover giving you a head start on releasing the clutch. This causes premature wear on the pressure plate, TOB, and you lose some clamping force on the disc.
You can't get the slave to travel more without pushing more fluid or using a slave with a smaller bore.
It is possible, and I can demonstrate on my car if you'd like. I literally just swapped in a new slave and went through this whole thing myself, trying to get some more travel at the fork. From my own personal experience at least, I can say it absolutely changes things. As I said above, I understand on paper, it shouldn't work, but it does (at least on my Galant).It's simply not possible to get more slave travel from changing the rod. The master pushes X amount of fluid, it does know or care what is on the other side of the slave piston.
You're right. I edited my posts above, which were misleading.The slave can be bottomed out in the bore, and still function. The master cylinder is the one that can block the return ports if your not careful.
Any info on part number or other about this 3/4" slave cylinder? I've read thru the entire thread & followed the links as well without finding enough info to try & get one for myself. I noticed the 95-96 (MD742158) slave p/n is different that the 97+ (MD749823). Would it be one of these that's the 3/4" slave?
Thanks for the pic!!! I pulled a 2g rod out of the junkyard yesterday, I'm going to put it in the car tonight and see if it fixes my issue.
You must be logged in to view this image or video.You must be logged in to view this image or video.
So once I block the relief valve, then back it out 1/2 turn or full turn (whatevever it takes to unblock the relief port), then I test for clutch drag again.I just finished installing mine. If you have a die, put a few more threads on it, about the width of the locking nut. It blocked the relief port even when it’s screwed all the way in.
Also, after you adjust the rod so the relief port isn’t blocked, use a sharpy and mark the rod. The rod will turn when you tighten the lock nut. This took me a few times.
If it is still dragging, or still engaging right off the floor, then just back it out a little more and test again, right?
