Anfurnyy
Supporting Member
- 1,491
- 1,904
- Jul 4, 2020
Rapid City,
South Dakota
I will say this is my fault. I know idle VE is low but with his global fuel and dead time where it was this is what put his AirflowPerRev roughly in line with where it needed to be and allow his car to at least idle a little bit.Here is your SD table - and in the idle area you are pulling out a LOT of fuel. Do you really want to pull fuel here? I think this is working against your global dead times. I know your cams are messing with you, but I would try a stock VE table to dial in Global dead time.
Obviously idle VE will change when he gets his global fuel figured out with a WOT pull but it's hard to even get to that point when the car won't idle right.
