7 bolt head??? or what?
EisHERE
188
Nov 13, 2012
Eau Claire, Wisconsin
I know that the head was ported and what not, but now I'm confused about the exhaust manifold area.. I took it off to do the broken mani studs (2) and I had ordered them for a 6bolt but look here, and I have a bigger bolt on each end. thankfully, the broken studs are on the outside of the head so I'm going to try and weld a nut on :hellyeah: but what I need to know now is what is up with this?? Do I send back the arp ss mani studs for a six bolt and get ones for the 7 or what? :S sorry i'm lost right now.
A 7 bolt head will have bigger studs on the outsides on the lower section of studs like you have pictured.
To be exact the 4 studs on top use 12mm nuts and on the bottom 5 studs the 2 on the outside are 14mm and the 3 in the middle are also 12mm.
July 1991. PO says it's a six bolt. but why would the manifold studs be diff sized if it is in fact a 6 bolt head? basically, I would have to buy a manifold gasket for a 7 bolt, and mani studs for a 7 bolt?
Its common to find a 7 bolt head on a 6 bolt short block.
That swap is getting done daily it seems.
post a pic of the therm housing.
I have never worked on or owned a 6 bolt head, I would like to assume that both 6 and 7 bolts are designed the way I described in my previous post. I could see why it was done that way - to give greater support for the turbo kit. I'm sure someone with knowledge of 6 bolt heads will chime in to give confirmation.
July Makes it a late 92 model. Technically a 93. So it may all be 7 bolt.
I just went and looked thu my pile of 4g heads. I will confirm some of the 1g, Large intake runner heads have tha large 10 mm exhaust studs in the outer corners.
Casting number of G6
OP That looks to be a 1g/6bolt therm housing.
You have the odd ball 6 bolt/1g head.
Keep the kit you have, change the 8mm studs out, leave the 10mm alone.
Throw the spare 8mm in your tool box for use at a later time.
PS, this isn't the original motor that was in the car. It was swapped for a different one. I will know what year he swapped it for shortly.
edit- was swapped for a 91. haha you guys are awesome. thanks for the help. I do need one of the bigger bolts though, only one remains. know the size?
It is an odd duck that is for sure.
G6 casting
Large intake runners
1g therm mounting
10mm end studs on the exhaust
NO front CAS mounting holes.
Takes the 11mm head bolts
center 2 measured at the HG surface .470
Snow... that would make it late 1g
Damn screwball DSMs....:ohdamn:
I have 2 of these heads, got to make sure to ream the head bolt holes.:aha:
Dale, all I want to know is if I was right about it being a late 1g head (which would've come mated to a 1g 7 bolt block) :p
Yes!! YES!! YES!! You, The almighty Snowboarder were right!!
I had to take a few mins, I only have some where between 14-20 of these heads in my shop, counting the Hyundai clones too. ROFL
I have the habit of calling all the big intake runners 1g heads, and all small intake runners 2g
I keep forgetting about this bastard head that looks 1g but bolts down 2g
No need for name calling now :)
It was fairly easy to identify since that's what I've been messing with in my car. Such a pain sometimes. Any 1g 7 bolt setups should not have been made.
I would have to agree..... Like I said, the 2 I have, when I get to finish machining them, they will be just run of the mill 1g heads, with the proper .500 head bolt holes i them!
Dale -- I know you said you were going to look into this at some point in time but not sure if you ever did. Very surprised Brian didn't remember (or failed to link, whichever the case may be) as well.
Eric's trick: http://www.dsmtuners.com/forums/newbie-forum/431917-2nd-gen-1st-gen-head.html#post152931766.
That would have immediately pointed to a 1G head. All 7-bolt heads had the two larger outer studs, so two and two together -- and assuming no one has been in there and changed anything -- it's clearly a 1G 7-bolt head.
Also for future reference:
http://www.dsmtuners.com/forums/newbie-forum/404339-how-distinguish-7-bolt-head-6-bolt-non-turbo-head-6-bolt-turbo-head.html
I slammed forgot about that.
I now have put both those links in my "cheat" link list! :D
