7 bolt head
You have to ream out all the Stud/bolt holes for it to bolt to the block. 7-bolts have smaller holes
For the 7 bolt head to fit on a 6 bolt block, you will need to drill out the head to fit the 6 bolt head studs/bolts.
Yes you can use a 7bolt head on a 4g64 with some modification too but it should work, and the 4g64 is not backwards like the 420A is. The 4g64 was change to the right side starting 2000- and up.
