7 bolt head rebuild
giles95gst
May 30, 2012
Lebanon, Virginia
Ok. I'm thinking about buying my friends GST but he thinks the valves are bent. I've found everything to rebuild the head. But if i rebuild the head and the valves are bent. do i need new valve guides?:hellyeah:
I would just replace everything. Dont reuse old parts just to have it fail shortly after you run it. Guides and seals are cheap. Do it right rhe first time.
You shouldn't be rebuilding the head if you have to ask those questions....
