For sale 2g Clean title GSX, houston
1995 GSX clean title heavily modified. Tuned on e85 houston,tx
$10,000.00
Looking for offers. Will post more pictures soon.
Ecm linkv3 tuned on e85 by abel racing in okc.
The good.
Engine:
Less than 2k miles
6 bolt
Weisco 9:1 pistons
Manly rods
Eagle crank
Acr 0.1 over race bearings.
Fp manifold
Evo 3 16g, compressor housing ported, billet 11 blade 1 piece compressor wheel rebuilt less than 100 miles ago.
Catless exaust, 3" all the way back i believe.
Fluid ampr harmonic balancer
Head.
Kiggly behive springs
Kelford 264/268 cams,
850cc FIC injectors
450 walbro pump
Amfr regulator
1g Cam angle sensor
Tial 50mm blowoff
Mishimoto 4 core radiator.
Brand new alternator
Brand new lower control arms,
South bend clutch disk and pressure plate.
Aem 3.5 bar sensor setup for speed density but currently tuned on maf.
The cars body is wrapped but and under the wrap is body filled and wetsanded to 1200 grit, should be just take off the wrap and spary if you wanted to.
I'm sure I forgot a lot.
The bad.
Car runs and drives fine***, suspension is really tight so you feel every bump.
***assuming the god damn driverside axel doesn't pop out of the intermediary shaft in the .middle of houston rush hour traffic.
Does run and drive enough to get up on a trailer though. I replaced it 4 days ago, maybe I bought the wrong axel and it's a really easy fix. Maybe it's just a retaining clip issue, I don't know, I don't care anymore at this point.
UPDATE: Following instructions from https://www.dsmtuners.com/threads/awd-front-drivers-axle-removal.253055/
The axel thus far hasn't popped back out even under heavy pulls. Will update if this changes
driver side front tire a little chewed up from a lower control arm failure(lower control arm has been replaced, new oem both sides)
Driver side L piece for skirting broke the clip and inside but still have it.
Driver side fender was kinda banged up and had to hammer back into shape. Bondo+re wrap and you won't notice it. Or if you're sick with metal work VERY fixable as well.
FirstTimeDSM
DSM Vehicle Classifieds
More in DSM Vehicle Classifieds
