- Thread starter
- #26
Cj Anderson
5+ Year Contributor
- 32
- 21
- Jul 15, 2018
Tacoma,
Washington
@chrisman287 I just check continuity on the 1g to 2g maf adapter all wires are good.
Yes I was looking at that too.The coolant temp is dropping when the battery voltage drops so I believe the change in voltage is real.
Probably "short" is not the right word because a short would normally blow a fuse or cause some smoke or blow something up. But heavy current anyway, if the voltage right on the battery posts is going down to ~8 volts.a heavy short that draws enough amps
I will purchase that cheap analog meter today and wire it to my battery, I agree the meter will be more accurate to check the battery draw. I'll go back and check all my grounds to make sure they are clean and tight. I believe the factory manual shows all the ground locations under the hood. I do have a second starter if the starter that is installed happens to be going bad but I think it might be a grounding issue or my new battery might be having issues. @steve I'll enable the idle switch before the next start-up. Do you think the AirflowPerRev is causing over over-fueling problem? As far as the coolant and intake temp I'll look into that.Yes I was looking at that too.
If we need to sort out whether the actual battery post voltage is getting dragged all the way down to 8 volts, he
could connect a voltmeter of some kind directly to the battery posts. He would need to be able to shoot video of it, or at least be able to watch it while sitting in the car to log some cranks.
An inexpensive multimeter will likely have a very low sample rate like 3 samples per second which is not very good for something like this. A cheapo analog 0-15 volt DC panel meter might actually be better (about $9 Amazon Prime), overshoot and all it might still be better.
In normal operation, the only thing I can think of that drags the battery to 8 volts is the starter, when it first engages the flywheel and the engine is not rotating yet, just for an instant the battery voltage will be about 8 volts. Like for about 1 sample which is 1/25th of a second or something like that in ECMlink.
Yeah maybe he just needs one of those round wire brush thingies that you clean up the battery posts with and clean up the hole in the cable clamps that go onto the posts.WRT the voltage, I suspect one or more loose/dirty connections on either side of the battery.
Did ECMtuning do anything repair wise with your ecu when they had it? Did they say anything like "replaced the capacitors and cleaned some electrolyte off the circuit board"? Have the capacitors ever been replaced? Quite often it happens that a person's problems trace back to something wrong with the ecu, and usually it's pretty cheap and easy to get those issues repaired by ECMtuning.yea I sent the ECU to ECMLink and they installed the chip new for me. There is some freshly painted parts maybe the grounds still have some paint on them but I tried my best to clean them off first. I have done a lot to this car I don’t know if it would be helpful to try and post every part added and every step relating to the engine and accessories.
