ECMlink No start ECMLink v3lite new install
eltitillo
73
Jan 21, 2011
Phoenix, Arizona
hi people let me explain what mods i have first k&n intake filter and hard inlet pipe, fmic, full 3'' turbo back exhaust no cat, 14b turbo ported, aftermarket boost gauge boost running at 10 psi, everything else is stock.
i bought an used 1995 ecu with ecmlink chip and the ecmlink v3lite package looks legit everything clean on the board looks OK, well I install the ecu i connect the laptop to ecu and work i installed stock maps and when i try to start the car it cranks sometime backfire the sounds like it wants to start for a second and then i tried with my stock ecu and the car runs fine no misfire well run perfect then i tried again with ecmlink ecu and nothing :banghead: . but i don't know what else to do i am thinking if i don't get help here i am going to send the ecu to ecmlink so they can check it out. but i would like to find out if you guys can help me out. Thanks
here is the log that i have.
Solution
Just a thought here, you run a 95 car have you checked the ecu? Have you checked the part# cause if its a 97 that is socketed your firing order may be wrong. Just a thought
try zeroing out your mafcomp table, zero the global deadtime and reset the idle airflow smoothing factor in direct access...
like so:
Solution
eprom ecu not running ''ecmlink chip inside''
MD312464 = 1/94-7/94
E2T61672
EB23[A-E]
stock non eprom ecu and running
MD335287 7/96-6/97 -
E2T61687
now what i am thinking right now is that my car is running with a97 ecu here is a picture
Uploaded with ImageShack.us
ok guys after changing the firing order the car started right up and running fine here is the log. Thanks to everybody for helping me out, i am really happy :hellyeah: now i can enjoy car more next i am going to upgrade the fuel system. thanks everybody again
