ECMlink no start?
i dont know cant post a log right now
but i cant hear the pump on startup
and plugs are dry
before car was running oke just no start after ecu install and clutch switch cable
i replaced the maf for speed density do i have to disconnect the maft from the ecu?
i just took off the connector from the maf and plugged in the sd connector i didnt disconnect the mafttranslator from the ecu
could that give a problem?
Are you running V3? If so, go into the Misc. Tab and turn on the fuel pump, see if that will turn it on.
Are you sure the ECU isn’t damaged?
Work with what you do know, you swapped the ECU and the car doesn’t turn on. Start there.
yes i am running V3 gonna try that tomorrow
ecu must be oke just came fresh from ecm tuning it was fully checked out
thanks for the reply
Fuel, spark, compression.
You can turn the fuel pump on manually via link and see if it's working that way.
are you getting fuel at the rail?
Do you have spark?
Are your injectors scaled correctly?
What was the car tuned on previously?
this is how the misc tab looks like see pic
still no injectors
do i have to do something else to get the injectors working?
i have spark and fuel at the rail
