- Thread starter
- #576
Anfurnyy
Supporting Member
- 1,493
- 1,910
- Jul 4, 2020
Rapid City,
South Dakota
Yeah I went for a drive today and got into some decent boost. About 16psi but didn't stay in it. Just getting a feel for everything. I think my wastegate spring is set at 20 so I didn't even crack the wastegateSo you’ve got 2 Walbro 450’s in your Full Blown hanger? That’s awesome, I went with dw340’s as I didn’t think the bell shaped 450’s would both fit, that’s cooland on break in I agree with Marty, i was doing wot pulls within 50 miles on my motor, 2nd gear up to 7000ish rpm’s, but up to that point I progressively revved it out more and more, and of course varied the rpm’s and load during driving, downshifted vacuum pulls etc, 1000 miles in so far and still have good oil pressure, and I enjoyed wastegate pressure (27psi) for almost a year before I turned it up, I’m sure that Garrett will feel fantastic at similar boost
, it doesn’t hurt to change it more than you may think it needs
Oh for sure! No stranger to break in oil changes.Just remember oil changes are your friend on a new motor, it doesn’t hurt to change it more than you may think it needs
, I assume the shavings never went thru the oil pump since I didn’t see any flakes in the head, talk about shitting yourself
. That’s real life “trials and tribulations of owning a built dsm”
Oof. That would freak me out for sure. I know with aftermarket pistons there's hardly any room, but aluminum rods and aftermarket pistons... That is definitely a worry of mine.I’m sure glad I changed mine right after the dyno session, went from a total HIGH on Friday to finding magnetic shavings in the oil the next day, per Steven’s recommendation I did an engine flush, after pulling the valve cover and verifying nothing was wrong or visible in the head/valve train, later found a broken oil squirter stuck to the magnetic plug! That was the following batch of oil after the flush which looked great minus the squirter
I think mines a 90amp not sure if that enough or not.If you already have a higher output alternator, EHPS pump would be an option, too!
EHPS is different from the Prius EPAS. EHPS just replaces the factory belt driven pump with an electric pump, like Volvo, MR2 etc etc. So no modification required on the rack itself. Installation would be much simpler, just install the pump and lines.I think mines a 90amp not sure if that enough or not.
I've heard of a Prius setup and another one but I can't recall what it was.
Did you resolve what is keeping your temps higher than desired? What are you using to review your closed loop trims?Well I drove it to work today! All went well, car got a tad hot, sitting at about 210 by the time I got to work. I need to remember what thermostat I have installed so I can adjust my fans around that. Also should figured out some sort of ducting for the intercooler-radiator/ condenser.
Still loud as ever but I guess it's not really any different than a side or hood exit. I probably won't drive it to work again until I get an exhaust.
The issue is that it's a 1g with a big front mount and no ducting. Pretty much a standard issue once you go with a bigger front mount on these cars apparently. I haven't done anything to try and fix it yet as I don't drive it much yet so it doesn't worry me too much. Definitely plan to in the future though.Did you resolve what is keeping your temps higher than desired? What are you using to review your closed loop trims?
I'm a really running in Traditional right now until I get the fuel table actually mostly dialed in. Then I'll switch to modelled multifuel for flex fuelIf you’re tuning in modeled mode then your fuel pressure is already adjusted for you in Link.
