1G What wastegate pressure for 16G
The lowest boost you will run. Factory is 8lb spring iirc. You don't need to worry about internals for a 16g. It will handle anything a 16g can throw at it.
Thanks, how much bar are 8lb? 0.5? 😅
This are the seller options:
OEM = 0.8 bar, but it ultimately depends on what you plan on doing with the turbo. There are a ton of variants like turbine backpressure and wastegate hole / flapper size that ultimately determine the base and peak holding pressure of any internal wastegate system, so even a 1.5-bar actuator may have a base boost pressure between 15psi and 18psi despite the spring cracking pressure being close to 22psi.
Also, this actuator selection is typically only something I've seen offered by some of the Chinese or Taiwan distributors. A word of caution- those units aren't what they're cracked up to be.
Please correct me if I am wrong, but don't MAP sensors also include the vacuum as part of the "Bar" rating? I may be wrong, no doubt, but I was thinking a 4 Bar would measure up to 14.5 x 3 = 43.5 because it considers one of the "Bars" as the inches of vacuum or negative pressure. Is this wrong? I was reading on a Fiero website and came across THIS article. I don't want to give out mis-information so anybody that can clarify this, it would be good for everyone.
Thanks!
Marty
I think your referring to the difference between Gauge and Absolute pressure measurements and MAP sensors are by name Manifold Absolute Pressure Sensor. They measure from absolute vacuum (or as close as possible) so a 4 bar range sensor measures from 0-4 bar or up to 3 bar over atmospheric pressure.
The typical wastegates are going to all be psig values just like a tire.
Thanks for the clarification Steve! :thumb:
I would hate to be giving out bad info.
it's a kinugawa, I don't think it's "gold" but not crap either
I'd use the 1 bar spring IMO, Why on earth would you ever want to run less than 15psi on a 16g? Wastegaste spring pressure should be 1/2 what your total boost is going to be. So a 16G is good for around 28 psi divided by 2 = 14. You are welcome.
already arrived! they are very fast, let's hope it goes well, I have a lot of work to do first, I will have to wait before mounting it
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
